Cross Over Distance and Feed Rate for intersection holes
Control the Feed Rate Across Intersecting Holes
Cross Over Distance is a new Cutting Parameter that determines whether the tool path crosses intersecting holes at the specified Cross Over feed rate or at the Step Over feed rate.
Created with NX CAM 11.0.0
Details
Specifying an appropriate Cross Over Distance and Cross Over feed rate allows you to cross full intersections at a higher feed rate. If the intersection is greater than or equal to the specified Cross Over Distance, NX crosses the intersection with 3 motions: Last Cut, Cross Over, and First Cut feed rates.
Video
(view in My Videos)
(If you have problems with the embedded player, you can download the attached .mp4 file.)
Self-Demo
Save the attached part file locally and follow the instructions in the .pdf document.
Do you have a question about this topic?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
Holder.jpg Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
