Display Tool Path Point Distribution
Siemens Genius Siemens Genius
Siemens Genius
Overview
This article shows how to visualize the point distribution generated by NX for 3D motion.
NX 5 introduced an improved point distribution scheme for the smoothest possible surface finish on 3D geometry. This updated processing is now applied to all 3 axis tool paths.
Created with NX 5
Details
Activate the ability to visualize point distribution
To 'Turn On' the ability to display the actual point distribution, you must set an ENV variable:
1. Create a new ENV variable by doing XXXX, type XXXX
2. Enter the following in the New System Variable dialog:
  • Variable name: UGII_CAM_TP_DISP_ENDPOINTS
  • Variable value: 1
Display point distribution
Once you've set the ENV above, you can now see the point distribution for each of your various operations by:
1. Start NX CAM (it is important to restart NX after setting an ENV variable for the change to take effect)
2. Open any operation
3. Replay tool path
4. Tool path will include visible points
Do you have a question?
Click 'Add a Comment' below to ask it. (You must be signed in to access this feature.)
About the Author
Lars Lars Okkels is in the Manufacturing Business Group at Siemens PLM Software and focuses on part manufacturing solutions especially for Mold & Die. He has been in the industry for over 15 years and enjoys supporting NX users applying innovative manufacturing technology solutions. Lars is originally from Denmark and now resides in Shanghai, China, with his family.
Best regards
Lars Okkels
Siemens, MBG
Comments
Is the environment variable still required in NX9?
LIVE Tech Tip Webinars
Watch NX experts demonstrate manufacturing best practices. Stay online for Q&A.
