Easily See Boundaries on 3D Surfaces
Boundary Projection for Area Milling
Overview
When using the Area Milling Drive Method, the contact cut area is now displayed on the part for trim boundaries that use a Contact tool position.
Created with NX CAM 9.0.3
Details
The projected contact cut area displays on the part surface. This graphic display is new and appears only when Tool Position is set to Contact.
To use this self-demo, save the attached part file locally and follow the instructions in the pdf document.
Do you have a question?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
Holder.jpg Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
