External Program Simulation in NX CAM Simulation
Workflows to start "External Program Simulation" in NX CAM Simulation
NX CAM 12.0.2
Overview
Simulating external NC Programs allows you to simulate NC-Code without using a Postprocessor. With the introduction of the NX CAM integrated Program Manager it is possible to handle external programs more efficiently. This ends up in a different workflow which is described in this TechTip
Thomas Feind, in the NX CAM Customer Success Team at Siemens PLM software, created the following tech tip video demonstration.
(view in My Videos)
Do you have a question about this topic?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
