This Tech Tip explains how to configure face milling operations to best cover long, narrow parts, so that cuts are always climb (or conventional) cuts and stepovers are made off the part on the short ends.
Using standard operations for face milling long parts is not satisfying in some cases.
A desired output is to use an alternative zig on the part, doing rapid motions outside the part, as seen below.
Click 'Add a Comment' below to ask it. (You must be signed in to access this feature.)
Lars Okkels is in the Manufacturing Business Group at Siemens PLM Software and focuses on part manufacturing solutions especially for Mold & Die. He has been in the industry for over 15 years and enjoys supporting NX users applying innovative manufacturing technology solutions. Lars is originally from Denmark and now resides in Shanghai, China, with his family. |
No pdf and no mp4.
Correct - Lars wrote this 3 years ago.
Do you have a question about the procedure?
