Faster Tool Path Updates - Re-generate Only the Non-Cutting Moves
Generate Non Cutting Moves Only
Overview
You can now re-generate only non-cutting moves for Surface Contouring operations that use the Area Milling Drive Method, which can result in significant savings in tool path processing time. If your modifications affect only the non-cutting motion, the system will recognize that the cutting passes are all unchanged and avoid re-calculating those parts of the tool path. For fine finishing operations on larger die faces, calculation time can be reduced by orders of magnitude.
Created with NX CAM 10.0.3
Details
In Surface Contouring operations that use the Area Milling Drive Method, you can now regenerate only non-cutting moves when only non-cutting move parameters have changed using the new Do Smart Regeneration when Possible option in Manufacturing Preferences.
Video
(view in My Videos)
(If you have problems with the embedded player, you can download the attached .mp4 file.)
Self-Demo
Save the attached part file locally and follow the instructions in the .pdf document.
Do you have a question about this topic?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
Holder.jpg Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
Comments
Does "Force Regenerate" override this?
Yes, the comment about this setting should clearly say this.
Contributors
LIVE Tech Tip Webinars
Watch NX experts demonstrate manufacturing best practices. Stay online for Q&A.
