Overview
Learn about the breadth of available options for customizing NX CAM and how to create a safe environment to configure the system on your own.
Details
Click 'Comments' below to ask it. (You must be signed in to access this feature.)
This question was asked during the live webcast:
Q: Is the next session going to cover how to distribute the customization to all users?
A: The next session will show how to build additional templates. In this session you learned how to make a folder for your template customizations. So when your co-workers want to use your customizations, you can help them create the same safe environment as described here. Then you can give them the new template part files to store there.
Q: Will there be a session regarding this procedure in a Teamcenter shared environment?
A: We will put that on our to-do list and cover it in the future. Thanks!
Q: Would it be possible to post a step by step of what you just did so that I don't have to go back over the videos over and over to get the details that I couldn't write notes on fast enough? Thank you, Mark!!! :-)
A: Here you go:
