Gouge Checking with Different Part and Cut Area Stock
Checking Gouges on Parts with Non-Uniform Stock
Overview
You can now perform gouge checking when different part and cut area stock values have been specified. The values are listed in an Information window.
Created with NX CAM 10.0.3
Details
Gouge Check now supports non-uniform Part Offset Custom Data, Part Final Stock Custom Data, Cut Area Final Stock Custom Data, and Part Side Stock and Floor Stock in Cavity Milling, Area Milling, and Zlevel Milling operations. NX also checks negative stock for gouges, and generates a warning if the negative offset is larger than the tool radius.
Video
(view in My Videos)
(If you have problems with the embedded player, you can download the attached .mp4 file.)
Self-Demo
Save the attached part file locally and follow the instructions in the .pdf document.
Do you have a question about this topic?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
Holder.jpg Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
