How to start the NX CAM trial version software on your machine
Community Manager
The NX CAM Trial download creates multiple shortcuts related to starting NX.
To start your software trail in the correct environment, please follow the these steps.
1. Under Windows Start->All Programs
2. Select All Programs
3. Select Siemens NX 11.0 folder, then select Manufacturing folder
4. Select CAM Express 11.0 to run the Trial.
5. This screenshot (below) is what your screen should look like in NX.  Next, you can view the helpful Manufacturing Tutorials to get started.  If you have any questions, please post them on the NX for Manufacturing discussion forum, and an NX CAM expert will help you.  If you have not already done so, please register as a member of the Siemens online community in order to ask questions and share your knowledge.
Help can also be found on the NX CAM Trial Offer Frequently Asked Questions page.   Thank you for taking NX CAM software for a 30-day test drive!
Comments
hello..i'm new to nx CAM...i need some basic documents to prepare for it..and i need to give a presentation on that..can anyone help regarding this..
Karthik.
Community Manager
Thank you for your inquiry.  Here are links to some basic information about NX CAM on the  Siemens PLM website:
https://www.plm.automation.siemens.com/en_us/products/nx/for-manufacturing/cam/
This page links to several other documents and videos about NX CAM and associated software.
https://www.plm.automation.siemens.com/en_us/products/nx/for-manufacturing/cam/#lightview%26url=/en_... CAM Brochure%26description=NX CAM – a complete solution for making better parts faster%26docType=pdf
I hope that this is helpful to you.
Thank you Stephanie, it is helpul. Smiley Happy
Hi All,
Can anyone give me solution for below issues.
I am using UG NX 9.0 on a system with Nvidia Quadro FX1500 graphics card.
Recently upgraded with new monitor Benq BL2420PT( 2550X1440), and connected with DVI to DVI cable.
Issue is NX is not working properly.
Issues like...scrol for Zoom in and zoom out not working properly....menu bar is blurr.
I have tried some things like...uninstalled and re installed updated Graphics card driver...
reinstalled monitor drivers....reinstalled UG NX also.
But doesnt work any one.
Can any one provide solution.?
Kiran
