Hybrid Additive Machining for Rotary Parts
Hybrid Additive Manufacturing for a Rotary Part
Overview
Hybrid Additive Manufacturing combines an additive metal deposition process with the traditional CNC machining subtractive process to produce highly complex prototypes and finished parts using a single machine tool setup. This tutorial illustrates the Hybrid Additive method on a rotary part.
Created with NX CAM 10.0.2
Details
The additive process begins with a machine capable of laser deposition. The part is created by fusing material that originates in the form of a powder, layering the material in a series of steps that eventually form a 3D component. The subtractive process involves removing material using traditional CNC machining methods. Both processes can be used during programming.
Note: Additive Manufacturing requires the purchase of an additional license.
Video:
(view in My Videos)
Do you have a question?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
Holder.jpg Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
Comments
What licenses are needed in order to use this?
VIP
VIP
@JSchraitle, currently this is only available through DMG.
Thank you Mark @MarkRief
When will this “Hybrid Additive Machining” be released in NX11? I did not find this module.
NX 11.0.1 should contain it.
@Stefan_Pendl Thank you!Expect!
waiting for NX dealer licence ! Verry good process !
All Best,
Lado
Solution Partner Innovator Solution Partner Innovator
NX11.0.1 QRM Update complated.
But I did not find the hybrid Additive Machining.
What is it?
VIP
VIP
This is only available with a DMG/Mori hybrid machining center, such as the Lasertec 65 or 4300.
Contributors
LIVE Tech Tip Webinars
Watch NX experts demonstrate manufacturing best practices. Stay online for Q&A.
