Overview
In Resource Manager, you can import tool vendor catalogs that are provided and maintained by tool suppliers.
The “MRL_Import_GTC_Class_Hierarchy.pdf” document provides instructions on how to import the class hierarchy structure for a GTC catalog.
If there is already a catalog in use from the same vendor, the existing class hierarchy from this vendor must be removed before importing an updated hierarchy.
Details on how to remove an existing GTC vendor catalog are described in a separate Tech Tip article “MRL - Replace GTC Class Hierarchy”.
