Machine cut regions in order from the highest to lowest ZM values
Top-Down Ordering in Area Milling
Overview
When using the Steep and Non-steep containment method in the Area Milling drive method, NX can now order cut regions from the highest to lowest ZM levels.
Created with NX CAM 11.0.0
Details
Order Regions is new and is available only if Method is set to Steep and Non-steep. Steep First retains the behavior from previous releases. Top Down is new and orders cut regions from the highest ZM to the lowest ZM (top of the part to the bottom by level), cutting flat regions first, non-steep regions second, and steep regions third where they have the same maximum ZM value.
Video
(view in My Videos)
(If you have problems with the embedded player, you can download the attached .mp4 file.)
Self-Demo
Save the attached part file locally and follow the instructions in the .pdf document.
Do you have a question about this topic?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
Holder.jpg Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
