Make Intelligent Tool Path Edits
Tool Paths connect up intelligently after making edits in the Tool Path Editor
Overview
Additional Transfer/Rapid options are now available when trimming tool paths that allow you to connect disjointed tool path segments relative to the part geometry clearance. These options behave in the same way as those used in the Non Cutting Moves dialog box.
Created with NX CAM 9.0.1
Details
Usiing new Transfer/Rapid options to connect segments after trimming the tool path.
To use this self-demo, save the attached part files locally and follow the instructions in the pdf document.
Do you have a question?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
Holder.jpg Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
