Merge Tool Paths
Merge Tool Paths
NX CAM
Multiple operations can now be combined into a single operation containing a single merged tool path.
(view in My Videos)
(If you have problems with the embedded player, you can download the attached .mp4 file.)
Do you have a question about this topic?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
BillStorrs.png Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
Comments
Hello, this is what version of Nx, where I find this is in the creation of operation?
In Siemens NX (1847) released January 2019, it is a new program order group type.
Nice to see this in NX.
Exactly 3 years ago, I wrote an App for Narrow channels which is still in use, to program 3-5 axis contour toolpaths in a desired step milling pattern to support variable level, variable step, variable depths. This also aids lights-out machining. Serves as an alternative for Sequential mill Looping option. Could introduce spring passes at needed areas . All of this in a simple interface with editing capabilities..
- Vasanth Sivanatarajan
@billstorrs Is it possible to share your sample part file which was showed in the video?
I tried to use this nice feature but I don't get the expected result. The trajectory obtained is not different from the sequence of my 2 initial operations
I am using NX1851 release
In which release does it work?
Franck
