Ramping while profiling in a Floor Wall Milling operation
Profile Ramping in Floor Wall Milling
Overview
You can now create a Profile cut pattern for Floor and Wall Milling operations that cuts continuously by ramping in a helical manner to a specified depth.
Created with NX CAM 11.0.0
Details
Prior to this enhancement, cut depths were defined only by Levels. Ramping produces fewer engages and retracts than cutting by levels. Walls may be vertical or tapered. If the walls are tapered, the smallest opening determines the size of the helix.
Video
(view in My Videos)
(If you have problems with the embedded player, you can download the attached .mp4 file.)
Self-Demo
Save the attached part file locally and follow the instructions in the .pdf document.
Do you have a question about this topic?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
Holder.jpg Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
Comments
Mr. Bill Storrs
I would like to know when this techniq will be available in 3D contouring?
IR 6906821 Request for Information (Desc: There is no Ramp On Shape engage option for surface contouring)
Thank you for the update.
Regards Tim.
