Remove Very Small Cutting Passes
Minimum cut length for Area Milling
Overview
You can now specify a minimum cut length for steep cutting in Area Milling operations. This allows you to remove very short cutting segments from the tool path.
Created with NX CAM 9.0.3
Details
The new Minimum Cut Length option eliminates tool path segments shorter than the specified value.
To use this self-demo, save the attached part file locally and follow the instructions in the pdf document.
Do you have a question?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
Holder.jpg Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
