Save the Specified Tool Axis
Overview
Saving the specified tool axis in fixed axis operations.
Created with NX CAM 11.0.1
Details
On multi-axis machine tools, multiple machine tool axis angle positions may be valid for cutting the part. NX now saves the specified tool axis with the operation.
Video
(view in My Videos)
(If you have problems with the embedded player, you can download the attached .mp4 file.)
Self-Demo
Save the attached part file locally and follow the instructions in the .pdf document.
Do you have a question about this topic?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
BillStorrs.png Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
Comments
I did it excatly as discribed in the video, but the tool axis change will be not saved...
Community Manager
Works as describes in NX11.0.1. Functionality is not available in earlier releases and may be different in later releases. If problem persists, please submit PR against software.
I work with this version
NX VersionNX 11.0.2.7
NX Phase7
NX PatchNX 11.0.2.7 MP2, 13Sep17. See Maintenance Pack letter for detailed list of fixes.
Parasolid-Version29.1 (build 259)
Any idea how to solve the problem?
We have the same Probleme here!
The machine allways turns arround the Part in the preview when we change the angel in the operation.
And if we regenerate the operation, the C axis value turn back to the beginning.
If there is someone who know a solution, please help Smiley Happy
Unable to play video. Please try again later.
(view in My Videos)
Hi
I am having the same problem, see video.
(view in My Videos)
Tony Mason
Hi
When there is no IS&V Machine loaded there are no Rotation axes shown.
If I reverse the direction of the Manipulator the direction is set back to its original orientation after Re-generating the Operation.
Can this behaviour be explained please?
Tony Mason
Hi Bill,
can you help to attach the Demo part...Thanks.
Did anybody get this resolved? I am having the same issues as described above.
Here is my current version:
Version: NX 11.0.2.7
Phase: 7
Patch: NX 11.0.2.7 Revised, 08Aug18. See Hotfix letter for detailed list of fixes.
Hello @pudisad,
The demo part is in the folder below.
%NX_INSTALLATION_FOLDER%\MACH\samples\nc_simulation_samples
You will find the files below in this folder.
sim08_mill_5ax_cam_fanuc_in.prt
sim08_mill_5ax_cam_fanuc_mm.prt
sim08_mill_5ax_cam_sinumerik_in.prt
sim08_mill_5ax_cam_sinumerik_mm.prt
sim08_mill_5ax_cam_tnc_in.prt
sim08_mill_5ax_cam_tnc_mm.prt
You can use any of these files.
I hope this helps.
Thanks.
Jean Marcel
PROLIM PLM
Contributors
LIVE Tech Tip Webinars
Watch NX experts demonstrate manufacturing best practices. Stay online for Q&A.
