Tool path no longer overlaps steep and non-steep cut patterns
Improved Tool Path for Steep and Non-steep Containment
Overview
When using the Area Mill Drive Method, the tool path no longer overlaps steep and non-steep cut patterns on faces with the same angle as the specified Steep Angle. The system now uses only the non-steep cut pattern.
Created with NX CAM 11.0.0
Details
Prior to NX11.0, steep and non-steep cut patterns overlap on faces with the same angle as the specified Steep Angle. In NX11.0, only the non-steep cut pattern is used on faces with the same angle as the specified Steep Angle.
Video
(view in My Videos)
(If you have problems with the embedded player, you can download the attached .mp4 file.)
Self-Demo
Save the attached part file locally and follow the instructions in the .pdf document.
Do you have a question about this topic?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
Holder.jpg Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
