Trim Cut Regions With Simple Sketches
Divide cut region using a line
Overview
You can now specify the orientation of the plane along which the divide line projects when dividing a cut region in Area Milling operations. This gives you more control over dividing the cut region.
Created with NX CAM 9.0.3
Details
You may define a sectioning plane through the divide line normal to the tool axis or define the sectioning plane by specifying an angle relative to the tool axis.
To use this self-demo, save the attached part file locally and follow the instructions in the pdf document.
Do you have a question?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
About the Author
Holder.jpg Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
