Overview
This is video 16 of 16 in a series about how to create and edit postprocessors with NX Post Builder.
Tech Tip by Jim Wright, Siemens PLM Software
Details
The NX Post Builder application is extremely flexible and powerful, and can provide useful benefits. This online Tech Tip series is intended as an overview of the post builder and postprocessing workflows in NX CAM.
Much of the content discussed in these videos is fairly advanced and while potentially valuable to everyone, it may be more useful to those of you with post processor experience. To get the most from this series, we suggest that you watch the videos in sequence. You can find the other videos in the Postprocessor section of this Tech Tip Knowledge Base.
Videos in this series:
Click 'Comments' below to ask it. (You must be signed in to use this feature.)
Jim & Aaron,
I followed along with Jim in this video; all went well until I tested the post. I kept getting an (sort of non-specific) error and finally tracked it down to the way the variable that we created is referenced.
It seems to only work if I program as such:
if { [info exists mom_nc_programmer] }
(checking to see if the variable exists) versus:
if { [info exists $mom_nc_programmer] }
(referencing the value held in the variable)
has anyone else ran into difficulty with this?
Hi Thunderbird,
I checked some of my old posts, and you are correct. You should use the first method (check to see if the variable exists) in this situation.
Jim Wright
Hi Jim,
Good vidoe. It helps. However I have a quick question for you.
I saw you placed the PB_CMD in First Tool block, however, I did the same thing and it said the mom_ variable doesn't exist. If I call the variable at Rapid Move block, then it works.
So I'm wondering when exactly will the UDE variable be "read" by NX or Postprocessor?
In addition, it seems like the "uplevel" command is a little bit too difficult to use and do you have any sample codes or tutorial on that as well?
Thank you!
Owen
Hi Owen,
I met the same problem as you too. The reason for this "mom_variable doesn't exist" can be: Instead of adding the UDE in the program head, you may be adding the UDE in one of the operations, say Face_milling, like the following pic shows:
While Jim's adding the UDE in the place where is the parent level of all the operation (in my case T12345-A), the post then creates the variable and "globalized" it in "Program Start Sequence". Later on, he would be able to use the variable anywhere after "Program Start Sequence".
The way the post works, I believe, follows the sequence shown on the left hand side of your postbuilder:
Rapid Move (in Motion block) is "behind" Machine Control block. So at the point where Rapid Move is called, Machine Control has already been executed. That's why it works at your latter case.
Stephan
我可以下载吗
