What's New in NX CAM 11 For Your Industry
Community Manager
This article is a summary of resources, organized by industry categories, describing NX CAM updates available with the NX 11 release. It includes new and improved functions delivered since the release of NX 10.0.0. Each item listed is linked to another article with more details.
Robotics Programming
Use Robots in Your CAM Setups
Easily Jog and Specify Poses in a Robotic Program
Production Machining (Prismatic Parts Machining)
Easily Drill Interrupted Holes (Core Drilling)
new_feature_group_dialog_box.prt
Easily Organize and Select your Workpiece Features
Optimize Drilling Sequences for Holes not In-line
Eliminate False Warnings during Verification of Tool Path
Track the position of Chamfer Tools
Reduce Transistion Motions and Cycle Time for Drilling
Cut Radial Grooves inside Holes
Customize Safe Transitions for Drilling Operations
Drilling Interrupted Holes Motion Output
Specify Tracking Points for Drilling Cycles and Non-cut
Drill Deep Holes
Cut Pockets to Full Depth When Using Collision Checking
Drilling Holes Normal to the Face of a Countoured Surface
Countersinking the Back Side of Holes
Drilling to Different Diameters with Stepped Drills
Mold and Die Machining
Manage Cutting Sequences for Valley Restmilling
Remove Very Small Cutting Passes
Trim Cut Regions with Simple Sketches
Achieve a Smoother Finish When Finishing Steep and Non-steep Overlaps
Automatically Smooth Out Cut Level Transitions and Engages
Easily See Boundaries on 3D Surfaces
Smooth Engages and Retracts for Trimmed Tool Paths
Achieve Optimal Corner and Pocket Rest Milling
Cut Across Undercuts in 3 Axis Milling
Using the Largest Possible Tool in Tight Spaces - Controlling Back-off Distances
Faster Tool Path Updates - Re-generate Only the Non-cutting Moves
Faster NC Program Updates - Re-generate Only what Changes
Complex Machining
Completely Machine Both Sides of a Blade without Edge Rolling
Hybrid Additive Machining for Rotary Parts
Graphically Analyzing Tool Paths by Color Display
General Improvements
Verify Tool Path in Fewer Steps
Speed up your NC Simulation
Edit Postprocessor custom functions with a smart TCL editor
Adding Detailed Work Instructions to CAM Operations
Improved Simulation Results with Separate Chordal and Tilt
Better Engages and Retracts for Odd Shaped Regions
Gouge Checking with Different Part and Cut Area Stock
Derek Hart
... if we're not having fun, we're not doing it right!
