What's new in NX 12 for your industry?
Community Manager
This article is a summary of resources, organized by industry categories, describing NX CAM software updates available with the NX 12 for manufacturing release. It includes new and improved functions delivered since the release of NX 11.0.0. Each item listed is linked to another article with more details.  Bill Storrs, in the CAM Product Management Group at Siemens PLM software, created the following tech tip video demonstrations.
Robotic programming
Robotic Machining
robotic pick and place programminig.gifRobotic Pick and Place Programming
Production machining (prismatic parts machining)
Mill Turn.gifMill Turn
orient work view.gifOrient Work View to Tool Axis or MCS
 IPW - 3D Holder Collision Check
ipw 2.gif IPW - Turning Support
ipw 3.gif IPW - Geometry View
display step over.gifDisplay or Hide Stepover Moves
rampling while.gifRamping while profiling in a Floor Wall Milling operation
explic.gifExplicitly locate and orient the IPW when machining multiple parts
controlling.gifControlling the depth of the chamfer tool by offsetting the drive point
control.gifControl the Feed Rate Across Intersecting Holes
gouge.gifGouge Checking consistency for Hole Making operation types
specifying.gifSpecifying multiple starts for thread milling operations
turning tool.gifTurning Tool Orientation Display
wire edm.gifWire EDM Nocore Lead In
wedm.gifWEDM Finish Cutoff Pass
tool and toolpath.gifTool and Tool Path Display Options
show 3d.gifShow 3D or Spinning 3D IPW
smooth non.gifSmooth Non Cutting Moves
mirror operations.gifMirror Operations
new boring.gifNew Boring and Chamfer Tools
turning workpiece.gifTurning Workpiece Inheritance
skip cut areas.gifSkip Cut Areas Where Engages Do Not Fit
smooth non cutting moves.gifSmooth Non Cutting Moves
improved performance.gifIPW - Improved Performance
smooth cutting in corners.gifSmooth Cutting in Corners Except the Last Pass
Mold and Die
roughing tool paths.gifRoughing Tool Paths that Adapt to Part Shape
CAM faceting.gifCAM Faceting
machine cut.gifMachine cut regions in order from the highest to lowest ZM values
smoothly remove.gifSmoothly remove scallops in the center and corners of the cut pattern
tool path no longer.gifTool path no longer overlaps steep and non-steep cut patterns
drive curve.gifDrive Curve Creation in Streamline
options to improve.gifOptions to Improve Finish Cuts in Area Milling
gouge checking.gifGouge Checking with Different Part and Cut Area Stock
depth first.gifDepth First Ordering in Area Milling
Complex Machining
machining tools.gifMachining Tubes and Ports
rough machining.gifRough Machining Tubes and Ports
interpolate tool.gifInterpolate Tool Axis Enhancements
data display.gifData Display
enhanced gouge.gifEnhanced Gouge Check Reports
tool axis.gifTool Axis Smoothing for Blade Machining
generate non cutting.gifGenerate Non Cutting Moves Only for Any Drive Method
tool tilt enhancements.gifTool Tilt Enhancements
interpolate 2.gifInterpolate Tool Axis Enhancements
General Improvements
time analysis.gifTime Analysis
probe output control.gifProbe Output Control
load ipw.gifLoad IPW From Operation
analysis consolidation.gifAnalysis Consolidation
enhanced ipw.gifEnhanced IPW Resolution
drag and drop.gifDrag and Drop
add feed items.gifAdd Feed Items to Operation and Method Dialogs
easily identify.gifEasily identify the tool needed when editing or creating an operation
displaying an.gifDisplaying an advanced view of the machine axis positions
save the specified.gifSave the Specified Tool Axis
organize.gifOrganize Dialog Groups into Nodes
dialog search.gifDialog Search
copying cam.gifCopying CAM Objects from a Component
Do you have a question about these topics?
Post your questions or comments at the bottom of this Tech Tip. (You must be signed in to access this feature.)
NX 12 press release:
Siemens' latest version of NX expands toolset for digitalizing the machine shop
About the Author
BillStorrs.png Bill Storrs is in the CAM Product Management Group at Siemens PLM software, Cypress California. His main focus is on CAM usability and learning support. He currently leads the CAM Learning Initiative Team whose mission is to provide users with a comprehensive collection of reference and training materials. He has an M.A. in Corporate Training and Development and has been in the industry for over 20 years.
