Prediction of Interior Noise in a Sedan Due to Exterior Flow
Aero-vibro-acoustic prediction of interior noise associated with exterior flow requires accurate predictions of both fluctuating surface pressures across the exterior of a vehicle and efficient models of the vibro-acoustic transmission of these surface pressures to the interior of a vehicle. The simulation strategy used in this paper combines both CFD and vibro-acoustic methods. An accurate excitation field (which accounts for both hydrodynamic and acoustic pressure fluctuations) is calculated with a hybrid CAA approach based on an incompressible unsteady flow field with an additional acoustic wave equation. To obtain the interior noise level at the driver's ears a vibro-acoustic model is used to calculate the response of the structure and interior cavities. The aero-vibro-acoustic simulation strategy is demonstrated for a Mercedes-Benz S-class and the predictions are compared to experimental wind tunnel measurements.
Publisher:
  • SAE
Author(s):
  • Alexander Schnell
  • Vincent Cotoni
Author's company:
  • Daimler AG
  • CD-adapco
Industry(ies):
  • Automotive
Product(s):
  • Simcenter STAR-CCM+
Date:
  • June 15, 2015
Link:
http://papers.sae.org/2015-01-2331/
