API: Selecting operation root levels.
Hi everyone,
I am quite new to process simulate and its API. Right now i am trying to access/select the last Via location Operation thats inside of a Compund Operation which is also inside another Compound Operation.
For more graphical explanation:
-Compund Operation
    -Compound Operation
        -Last Via LocationOperation
Right know i have been able to filter the the first level of compond operations but have no idea on how to access that second level and so on. For filtering on that first level i used:
TxTypeFilter Sel_Filter = new TxTypeFilter(typeof(TxCompoundOperation));
            TxObjectList Selection_1 = TxApplication.ActiveDocument.OperationRoot.GetDirectDescendants(Sel_Filter);
 Would it make sense to get all compound operations and then filter them depending on the level that they are?
Could anyone help me by giving some direction on how to proceed from here?
Sorry for the newbie question and thanks in advance
Re: API: Selecting operation root levels.
Hello Lucas
Maybe the code below can help you achieve what you want, please let me know if this is what you're looking for and try to compile it. The code below looks for a compound operation name, but you can adapt for your particular needs.
            foreach (TxCompoundOperation compOp in Selection_1)
                if (compOp.Name == "The name of desired compound")
                    TxObjectList weldList = compOp.GetAllDescendants(new TxTypeFilter(typeof(TxRoboticViaLocationOperation)));
                    TxRoboticViaLocationOperation lastViaLoc = weldList[weldList.Count - 1] as TxRoboticViaLocationOperation;
Thanks FredCastro, that was a good solution on how to proceed. But now the next road block appears, this identying of robot via location needs to be done in a iterative way until no more last via locations are found. This would mean that inside of the "Selection1" there is more than just one(unknown number) CompoundOp where you need to get that last via-location.
I have tried to look for a way of renaming "Weldlist" but seems like you cant dynamically create a list inside a for loop.
Any idea/hint on how to proceed?
Thanks once again for your help.
Maybe something like this can work. You'll have an array list of last via locations at the end.
            TxRoboticViaLocationOperation[] lastViaList = new TxRoboticViaLocationOperation();
            int i = 0;
                    lastViaList.SetValue(lastViaLoc, i);
                    i++;
PS: I'm not actually compiling the code, just trying to give you ideas.
Hi Lucas_SWE,
Do you really have only compound operations and not weld operations or other robotic operations?
If only compound operations, then FredCastro gave you a good example. I would only add that in order to access the compounds on the second level you need one more time to get the DirectDescendants of type TxCompoundOperation.
foreach(TxCompoundOperation compoundOp in Selection_1)
     TxObjectList Selection_level_2 = compoundOp.GetDirectDescendants(Sel_Filter);
     foreach(TxCompoundOperation op in Selection_level_2)
            //here use the code that gets the vias
Best Regards,
DianaG
Just to add and make things easier ive built an extension library to help speed things along.
public static class TecnomatixEx{
public static List<T> GetAllDescendants<T>(this ITxObjectCollection obj)
where T:ITxObject
var filter = new TxTypeFilter(typeof(T));
var = obj.GetAllDescendants(filter)
 .OfType<T>()
 .ToList();
return result;
public static List<T> GetDirectDescendants<T>(this ITxObjectCollection obj)
where T:ITxObject
var result = obj.GetDirectDescendants(filter)
   .OfType<T>()
   .ToList();
return result;
then you can just do
var items = TxApplication.ActiveDocument.OperationRoot.GetDirectDescendants<TxCompoundOperation>()
   .SelectMany(o=>o.GetDirectDescendants<TxCompoundOperation>();
foreach(var item in items)
  // Do yourstuff here.
I know it does the same thing but the extension really helps over time.
