Accessing the current user name
Is it possible to access the current user name for a Process Simulate session that's connected to an eMServer using the API?
I'm using PS V12.1 and V13.1.2.
Thanks.
10 REPLIES 10
Re: Accessing the current user name
Is anyone from Siemens able to answer this question?
Siemens Legend Siemens Legend
Siemens Legend
Hi.
No there is no API for that.
Thanks for coming back to me.
You need to use EmServer COM Library for this,
int session = TxApplication.ActiveDocument.eMSSessionId;
EMPAPPLICATIONLib.EmpApplication empApp = Microsoft.VisualBasic.Interaction.GetObject("","EmpApplication.EmpApplication") as EMPAPPLICATIONLib.EmpApplication;
EmpObjectKey userObjKey = empApp.CurrentUser;
new EmpNodeClass().get_Name(ref session, ref userObjKey);
Thanks for sharing this.
The last line doesn't look to be valid, however. I can't find where EmpNodeClass() is defined. Any help would be appreciated.
You can find it in "EMPMODELLib.dll" in emPower folder,
To get this to work, I had to tweak it slightly:
EmpApplication empApp = Microsoft.VisualBasic.Interaction.GetObject("", "EmpApplication.EmpApplication") as EmpApplication;
EmpContext context = new EmpContext();
context.sessionId = session;
return new EmpNodeClass().get_Name(ref context, ref userObjKey);
Thanks again for your help! :-)
You are right, I'm missing EmpContext ...
hello  tphuy i try this code in my project, but there are 2 errors in it, does i miss some using or do something wrong? thank you very much the capture is in the belowcapture1.PNG
