Add geometory to LogicalGroup
I added an element add to "LogicalGroup" using TxLogicalGroup.Add() method.
But after I wished because it was an error, it wasn't obtained.
Is there anyone who knows about how to "Add LogcalGroup".
(Sample code)
// Create grometory TxComponent targetComp = ....; // Created by PhyscalRoot.CreateEquipment()
TxPolylineCreationData polyData = new TxPolylineCreationData(----);
TxPolyeLine polyLine = targetComp.CreatePolyline(polyData);
TxSolidByExtrudeCreationData extrudeData = new TxSolidByExtrudeCreationData(----);
targetComp.CreateSolidByExtrude(extrudeData);
// Create group
TxLogicalGroup parentGroup = ....; // Parent group is TxLogicalGroup("Group2")
string strGroupName = "SubGroup_1";
TxLogicalGroupCreationData gpData = new TxLogicalGroupCreationData(strGroupName);
TxLogicalGroup targetGroup = parentGroup.CreateLogicalGroup(gpData);
targetGroup.Add(targetComp); // This code exception ("Error in the application.").
8 REPLIES 8
Re: Add geometory to LogicalGroup
You can add already existing component to the logical group, or if you want to create the component you should follow the steps described here.
After that, the code for logical group that you use is correct:
// Create group
targetGroup.AddObject(targetComp);
Hi DianaG
Thank you for your reply.
I will try that step.
Hi DianaG
I tried the sample of component creation.
But TxNotSupportedInTCPlatformException was thrown and could not be executed.
I forgot to tell you, but I have implemented add-on for PS-R connected to TC.
Is there restriction on creating models in this environment?
Hi KKuwahara,
Yes, the code, that I gave you a link to, is only for PS on eMS.
We don't support component creation on Teamcenter platform via the API yet.
You can add the geometry to already existing component and add that component to the Logical Group.
Best Regards,
Diana
Hi Diana
I understood that it is an environmental problem. I will consider another method.
Thank you.
Hi!
 I want to know what was omitted in this code“TxLogicalGroup parentgroup=....”?
 I‘ m grateful for  any reply!
Hi Remond
string strName = "Group2";
TxLogicalGroupCreationData gpData = new TxLogicalGroupCreationData(strName );
TxLogicalGroup parentgroup = TxApplication.ActiveDocument.LogicalRoot.CreateLogicalGroup(gpData);
Hope this helps.
Hi KKuwahara
It works. Thanks a lot!
Best Regards,
Remond
