All _Planningpart
i have tried this way to get all planning parts, but i could nt get it. Can somebody help me?
private TxObjectList GetListOfParts()
TxObjectList parts = TxApplication.ActiveDocument.PhysicalRoot.GetAllDescendants(new TxTypeFilter(typeof(TxComponent)));
TxObjectList pla = parts.PlanningRepresentations;
TxTypeFilter partsFilter = new TxTypeFilter(typeof(TxPlanningPart));
TxObjectList plan = partsFilter.Filter(pla);
TxObjectList pParts = plan.EngineeringRepresentations;
return pParts;
private void button2_Click(object sender, EventArgs e)
GetListOfParts();
Re: All _Planningpart
Hello @ChristyBell
Have you tried to return the object list in your button click event and check if the objects are inside of it?
TxObjectList list = GetListOfParts();
Regards!
Hi @FredCastro,
sorry Fred, I thought ,your given command will work. But it did not worked. In Forum i found that method is right. So what should be the problem in my study, that i donot get list of any objects of particular type. Can you give some ideas to solve it?
TxObjectList robot = TxApplication.ActiveDocument.PhysicalRoot.GetAllDescendants(new TxTypeFilter(typeof(TxPlanningPart)));
            return pParts      ;
Can you also suggest whatare differance between above two code interms of output?
