Collapse a node in object tree via API
can I collapse a node in the object tree?
Jan
Re: Collapse a node in object tree via API
Hi Jan,
Currently there is no API exposed for that. You can use the command manager: TxApplication.CommandsManager.ExecuteCommand("TreeCommands.CollapseLevel");
Have in mind that the command may change in the future releases.
Best Regards,
DianaG
