Create a Interference Volume (based on SweptVol + InterferenceVol)
Hi everyone again,
I have been working a bit with Swept and Inteference volumes lately and today I thought about the posiblity of creating an Interfence Volume (IV) that is the result of a Swept Volume (SV) and an IV.
The reason why I came down to this idea is because I am checking where robots collide with each other. Sometimes I find out that there is posibilty of collision of 3 robots in one area and by being able to combine 3 SVs [IV (contains 2 SVs) + 1 SV] the algorithms gets simplified.
I have tried to find information on the SDK but cant get anything useful.
My idea was to type cast an IV as an SV (preferably first make a copy of the IV) and then use the built-in tool to perform the calculation of the new IV.
Has anyone tried this before? Could you give me a direction to head to?
Thanks in advance for your help.
Re: Create a Interference Volume (based on SweptVol + InterferenceVol)
Siemens Legend Siemens Legend
Siemens Legend
Hi
Though your idea to get the common volume for all 3 robots is conceptually right , you can not do that, as the SV and the VI are 2 different classed and you can not type cast one from the other.
Regrads
