Customized OLP commands via the API
I would like to access the customized OLP commands layers via the API.
I can iterate through the operations, and for each TxWeldOperation and TxRoboticViaLocationOperation I can then iterate through the list of commands, but for customized commands it returns a string containing delimited properties (i.e. OLP_CUSTOMIZED_COMMAND_NAME=...;OLP_CUSTOMIZED_COMMAND_ID=...).
How do I access the different layers of this customized command?
I've looked through the documentation and nothing seems like the obvious choice.
I am using PS V14.
Thanks.
Re: Customized OLP commands via the API
Siemens Legend Siemens Legend
Siemens Legend
you can use TxOlpCommandServices.GetCommandRepresentation under namespace Tecnomatix.Engineering.Olp.
Moshe
Thank you, Moshe.
