Different controls of tecnomatix
Hello ,
I have just started .Net API. I found there are many controls for Tecnomatix like TxObjEditBoxCtrl, TxObjComboBoxCtrl,TxObjGridControl,TxFrameEditBoxCtrl and Tx3DVectorCtrl. What are the uses for particular controls. Suppose i want to get a list of particular type of objects , so which control sould be used?
Re: Different controls of tecnomatix
Hi Vaghniku,
For a list of objects you can use the TxObjComboBoxCtrl or TxObjGridControl. Depending on the technology, you can use the controls that are under the WPF namespace or the winforms ones.
You can check also this video on how to add UI to your commands.
Best Regards,
DianaG
