Each time I try to access the "color" property of ITxDisplayObject, I get an exception ...
Siemens Legend Siemens Legend
Siemens Legend
Question:
Each time I try to access the "Color" property of ITXDisplayObject, I get an exception that it isn't accessible.
Answer:
The Color property of ITXDisplayableObject returns a valid color only if the component has a uniform color and that color is explicitly defined.
You can use the getColors() method instead- it returns all the colors of the object.
