Error Handling
Hello everyone,
I am trying to get rid of error message "inflow rate is less than the outflow" using the error handler. Does anyone have any experience on how to use error handler.
Thank you!
4 REPLIES 4
Re: Error Handling
Hi Parag,
Can you give more details?
Which error handler (which class) do you use?
What is your workflow?
Best Reagrds,
DianaG
Re: Error Handling
Hey Diana,
Thank you for replying.
I am working with fluids class, and not able to understand the error handler application at all. I want to get rid of two types of error: inflow rate is less then the outflow, tank A can accept only single type of material.
I am working on a process plant. In one of my module the fluid gets seperated into two different by-products which then needs to pass through the tanks following it .
I already tried usind waituntil commands to make sure fluid enters the tank only if it is empty, but in this I am exceeding the amount of call chains.
Kind Regards,
Parag
Re: Error Handling
Hi Parag,
Sorry, but we cannot help. Here is a link to thePlant Simulation forum
Tecnomatix .NET API Developer Forum is for API on top of Process Simulate and RobotExpert applications.
Best Regards,
DianaG
Re: Error Handling
Hey Diana,
No problem. Thanks a lot anywyas.
I found an alternative solution anyways. But I will try to ask in that forumas well, may be I find a solution that can help me learning further.
Best Regards,
Parag
