Get Collision curves by C# API
Hello Experts,
Is it possible to get collsion results (collision curve) by C# API?
if Yes, Please share the details.
Thanks in advance.
Ravi
10 REPLIES 10
Re: Get Collision curves by C# API
Hi Ravi,
Do you mean the collision contour that is generated when you press Show/Hide Colliding Contour?
Best Regards,
DianaG
Hello Diana,
Yes, I am interested to get collision contour that is generated when you press Show/Hide Colliding Contour.
Ravi
Hello @Ravi104484
Check the code below and see if it is what you need. It will display all collision contours in graphics viewer.
            TxCollisionQueryParams collisionParams = new TxCollisionQueryParams();
            collisionParams.StopQueryAfterFirstCollision = false;
            collisionParams.Mode = TxCollisionQueryParams.TxCollisionQueryMode.DefinedPairs;
            collisionParams.ReportLevel = TxCollisionQueryParams.TxCollisionReportLevel.LowestLevel;
            collisionParams.FindPenetrationRegions = true;
            TxCollisionQueryResults collisionResults = TxApplication.ActiveDocument.CollisionRoot.GetCollidingObjects(collisionParams);
            ArrayList collisionStates = collisionResults.States;
            foreach (TxCollisionState state in collisionStates)
                TxPenetrationRegion[] penetrationRegionVector = state.PenetrationRegions;
                foreach (TxPenetrationRegion penetrationRegion in penetrationRegionVector)
                    TxManipulatorCreationData manipData = new TxManipulatorCreationData("manipulator", new TxTransformation());
                    TxManipulator manip = TxApplication.ActiveDocument.PhysicalRoot.CreateCollisionContour(manipData);
                    TxVector[] intersectionCurveVector = penetrationRegion.IntersectionCurve;
                    ArrayList intersectionCurveList = new ArrayList(intersectionCurveVector);
                    TxManipulatorPolylineElementData polyData = new TxManipulatorPolylineElementData(new TxTransformation(), intersectionCurveList);
                    manip.AddElement(polyData);
            TxApplication.RefreshDisplay();
Hello Ravi,
FredCastro gave you the right example. You can also play with the properties of TxManipulatorPolylineElementData and change its color, state, pickability, etc.
Thank you @FredCastro
Best Regards,
DianaG
Hello FredCastro,
Thanks a lot for your help and inputs.
Ravi
Hello Diana,
Ravi
@Ravi104484
Nice to know it helped you!
@DianaG
You're welcome! I'm actually thinking in an API to estimate a volume based on the collected points from the collision contour. It doesn't need to be a 3D solid, I just want to get a volume value and compare with a threshold.
Do you have any suggestions on that?
Hi FredCastro !
For this code:
 I have tested the other collisionParams.Mode :
collisionParams.Mode = TxCollisionQueryParams.TxCollisionQueryMode.All;
It seems that there is no difference between them when the code runs,do you know how they make a difference to collision set ?
Hello @Remond
When you use "defined pairs", only checked collision sets will be considered in collision analysis. When you use "all", all objects in current study will be considered in collision analysis (it is the same as the "All displayed objects" flag in collision viewer, as shown below):
You probably got the same results because both analysis are resulting in same colliding objects.
Regards!
