Get component 3D model path
Hello;
I try get list of components from disconnected cell. Can somebody write how to get property 3d model path (to .cojt folder). Thank You
Re: Get component 3D model path
if the component is saved in the library this should work:
ITxStorable StorableComponent = Component as ITxStorable;
TxLibraryStorage newLibaryStorage = StorableComponent.StorageObject as TxLibraryStorage;
sSourcePath = newLibaryStorage.FullPath;
Kind Regards,
Mario
