Getting Signal change time
I am trying to find specific simulation time for when a signal changes his value.
The purpose of this is get those times in a report for establishing devices cycle times(similar to Robotic cycle time report command )
The problem i encounter is that the time that gets written in the .txt is the end simulation time. I would like to write the time when signal value changes.
Here is my code :
public override void Execute(object cmdParams)
TxDocument active = TxApplication.ActiveDocument;
TxPlcProgramRoot progRoot = active.PlcProgramRootOrNull;
if (progRoot != null)
TxPlcProgram prog = progRoot.CurrentPlcProgramOrNull;
if (prog != null)
TxTypeFilter filter = new TxTypeFilter(typeof(TxPlcOutputSignal));
TxObjectList sigs = prog.GetSignals(filter);
TxApplication.ActiveDocument.SimulationPlayer.Play();
foreach (TxPlcOutputSignal sig in sigs)
var Val = sig.Value.BooleanValue;
string value = Convert.ToString(Val);
if (Val == true)
var time = new TxSimulationPlayer();
string time_value = Convert.ToString(time.CurrentTime);
string[] lines = { time_value };
System.IO.File.WriteAllLines(@"E:\folder\WriteTime.txt", lines);
Any ideea how i can get the specific time of the changing value of signal?
Thank you .
Re: Getting Signal change time
Hi Lonut,
You can check this post.
Best Regards,
DianaG
