Getting an Error "Exception thrown: 'System.AccessViolationException' in Implementation.dll"
How to habndle this error  ?
Sandeep
7 REPLIES 7
Re: Getting an Error "Exception thrown: 'System.AccessViolationException' in Implementation.dll"
Siemens Legend Siemens Legend
Siemens Legend
Can you please share the code that throws this exception?
TxComponent.SetModelingScope()
Siemens Legend
And can you set the scope for that object via the UI?
Yes !
@sandeepmore
Why dont't you surround your TxComponent.SetModelingScope() with a try-catch?
Did but no luck, Techomatix is crashing with access AccessViolationException, what I am seeing in call stack
Siemens Legend
hi,
Can you share your entire code +data ?
If you need i can provide a secure connection for the file transfer.
