Getting unknown error while objectRobot.GetPoseConfiguration(posedata)
Hi Team,
I am creating new operations and viaroboticlocations and assigning an robot and gun to those welding operations.
I want to acheive robotic simuation by these via locations but getting unknown error at Txrobot.GetPoseConfiguration(posedata). I am using below code for the reference.
TxDocument doc = TxApplication.ActiveDocument;
TxOperationRoot operRoot = doc.OperationRoot;
TxServoGun objGun = TxApplication.ActiveDocument.GetObjectsByName("vagba_1900001043")[0] as TxServoGun;
ITxRobot object_robot = TxApplication.ActiveDocument.GetObjectsByName("s11r02")[0] as ITxRobot;
if (object_robot != null && objGun != null)
try
ArrayList list = new ArrayList();
list.Add(5.00 ); list.Add(-40.00 ); list.Add(14); list.Add(-86 ); list.Add(-72 ); list.Add(-25.00 );
TxPoseData posedata = new TxPoseData();
posedata.JointValues = list;
list.Clear();
ITxRobot objectRobot = object_robot as ITxRobot;
TxRobotConfigurationData roboConfigdata = objectRobot.GetPoseConfiguration(posedata);
TxTransformation absLoc = objectRobot.GetTCPFByPoseData(posedata);
//Create Compund operation first
TxCompoundOperationCreationData compoundOpnData = new TxCompoundOperationCreationData();
compoundOpnData.Name = "Compound_Opn_" + op_id;
TxCompoundOperation compoundOpn = operRoot.CreateCompoundOperation(compoundOpnData);
//Create Weld operation and assign it as robot and gun as resource.
TxWeldOperationCreationData wldopnData = new TxWeldOperationCreationData();
wldopnData.Name = "WeldOpn_" + op_id;
TxWeldOperation weldOperation = compoundOpn.CreateWeldOperation(wldopnData);
weldOperation.Robot = objectRobot;
weldOperation.Gun = objGun;
weldOperation.Duration = 15;
//Create ViaLocation operation
TxRoboticViaLocationOperationCreationData roboticViaLocationData = new TxRoboticViaLocationOperationCreationData();
roboticViaLocationData.Duration = 15.00;
roboticViaLocationData.Name = "via_Loc" + op_id;
TxRoboticViaLocationOperation roboticViaLocationOpn = weldOperation.CreateRoboticViaLocationOperation(roboticViaLocationData);
roboticViaLocationOpn.AbsoluteLocation = absLoc;
roboticViaLocationOpn.RobotConfigurationData = roboConfigdata;
roboticViaLocationOpn.Locate(absLoc);
catch (TxException e)
MessageBox.Show(e.Message.ToString());
4 REPLIES 4
Re: Getting unknown error while objectRobot.GetPoseConfiguration(posedata)
Hi Sandeepmore,
Can you check in debugger what are the values in posedata.JointValues, before you call to
Best Regards,
DianaG
How to clear Teach Location
Is there any way to clear a location's Robot Configuration?
Re: How to clear Teach Location
roboticViaLocation.RobotConfigurationData = null;  will this work ?
But why you want to clear it ????
Yeah,it works well!
Thanks a lot.
It's better  to clear it because I need to move the roboticViaLocation to another location.
