How do I get the correct string for a particular button?
Siemens Legend Siemens Legend
Siemens Legend
Question:
In general how do I get the correct string for a particular button? Is this documented somewhere.
Answer:
There are commands that cannot be executed with CommandsManager, because they are not designed so.
As we cannot guarantee that the commands’ logic will not be changed in the future versions, we recommend using .Net API methods rather than calling commands with CommandsManager.
The recommand usage of the CommandsManager is to execute your command , so that you can maintain it upon any change.
