How get External ID from component?
Please give me information how I can get External ID from component. Thank You.
Betreff: How get External ID from component?
Here an example with robot:
        public string GetExternalId(TxRobot robot)
            return robot.ProcessModelId.ExternalId;
Hello;
I prepard function for get ExternalID from each component. I have question how to check if I put all possible types inside. Below is function:
private string strGetExternalID(ITxComponent InputComponent)
TxComponent newTxComponent = InputComponent as TxComponent;
TxDevice newTxDevice = InputComponent as TxDevice;
TxRobot newTxRobot = InputComponent as TxRobot;
TxGun newTxGun = InputComponent as TxGun;
TxGripper newTxGripper = InputComponent as TxGripper;
TxHuman newTxHuman = InputComponent as TxHuman;
TxPneumaticServoGun newTxPneumaticServoGun = InputComponent as TxPneumaticServoGun;
string strExternalID = "";
try
if (newTxComponent != null) strExternalID = newTxComponent.ProcessModelId.ExternalId.ToString();
if (newTxDevice != null) strExternalID = newTxDevice.ProcessModelId.ExternalId.ToString();
if (newTxRobot != null) strExternalID = newTxRobot.ProcessModelId.ExternalId.ToString();
if (newTxGun != null) strExternalID = newTxGun.ProcessModelId.ExternalId.ToString();
if (newTxGripper != null) strExternalID = newTxGripper.ProcessModelId.ExternalId.ToString();
if (newTxHuman != null) strExternalID = newTxHuman.ProcessModelId.ExternalId.ToString();
if (newTxPneumaticServoGun != null) strExternalID = newTxPneumaticServoGun.ProcessModelId.ExternalId.ToString();
catch
strExternalID = "";
return strExternalID;
Hi
Is this not simpler and does the same and you don't have to worry about the type.
public string getexternal(ITxPlanningObject obj)
 string id = obj.ProcessModelId.ExternalId;
 if (!string.IsNullOrEmpty(id)) {
  return id;
 } else {
  return "";
A quick look in the .Net help file:
Inheritance Hierarchy
System.Object
      Tecnomatix.Engineering.TxBaseGeometryCreationObject
         Tecnomatix.Engineering.TxBasePlcConveyor
         Tecnomatix.Engineering.TxComponent
         Tecnomatix.Engineering.TxConveyor
         Tecnomatix.Engineering.TxDevice
         Tecnomatix.Engineering.TxGripper
         Tecnomatix.Engineering.TxGun
         Tecnomatix.Engineering.TxHuman
         Tecnomatix.Engineering.TxPaintGun
         Tecnomatix.Engineering.TxPneumaticServoGun
         Tecnomatix.Engineering.TxRobot
         Tecnomatix.Engineering.TxServoGun
         Tecnomatix.Engineering.TxTcPlcResource
         Tecnomatix.Engineering.TxTool
HI
Yes but ITxProcessModelObject is an interface to all of these and hence TxProcessModelId is available
I think Blumenbecker's problem is to loop over all the different objects (TxComponent, TxDevice,...) in the resource tree.
In my opinion, casting is the biggest problem in this case.
At the moment, I cannot try this to provide a solution for this.
And I also have to read the helpfile first.
