How to access sealed class TxActivateCollisionSetsEvent and TxDeactivateCollisionSetsEvent?
I am confused about the TxDeactivateCollisionSetsEvent and TxActivateCollisionSetsEvent.
When I GoToDefinition in C#, I find that both of them do not have the constructor and are sealed classes.
Get the Tipp form here
https://social.msdn.microsoft.com/Forums/en-US/613f243f-abe9-4489-bdba-eb52b6e4c97b/how-to-access-se...
I just try to create a new Class extenting the Method AddCollisionSetToActivate(TxCollisionPair)
namespace TxCenseInterface
    public static class ExtentedTxActivateCollisionSetsEvent
         public static void ExtentedAddCollisionsetToActivate1CollisionSet(this Tecnomatix.Engineering.TxActivateCollisionSetsEvent txActivateCollisionSetsEventIn1)
             TxCollisionPairCreationData data = new TxCollisionPairCreationData();
             data.Name = "hopeItWorks";
             data.FirstList = xxList;
             data.SecondList = xxList;
             txActivateCollisionSetsEventIn1.AddCollisionSetToActivate(TxApplication.ActiveDocument.CollisionRoot.CreateCollisionPair(collisionPairDataCheckedPart));
And in API i wirte
//Here get the eroor again it says 'TxActivateCollisionSetsEvent' does not contain a constructor that takes 0 arguments
TxActivateCollisionSetsEvent txActivateCollisionSetsEvent = new TxActivateCollisionSetsEvent();
txActivateCollisionSetsEvent.ExtentedAddCollisionsetToActivate1CollisionSet();
But from the Tipp New-> Project -> Application Console -> follow the guys Tipp to write
public sealed class MyClass
    public void Test()
        Console.WriteLine("Test");
public static class MyClassExtender
    public static void ExtendedTest(this MyClass instance)
        Console.WriteLine("Starting to test...");
        instance.Test();
        Console.WriteLine("Test finished");
public static void Main()
    MyClass test = new MyClass();
    test.ExtendedTest();
This works fine to print out:
Starting to test...
Test
Test finished
So can somebody help me to solve the problem?
Best Regards,
Mei
Re: How to access sealed class TxActivateCollisionSetsEvent and TxDeactivateCollisionSetsEvent?
1. You cannot inherite any sealed class. The modificator sealed added exacly to avoid the inheritance.
2. I don't know why do you need to create a new instance of the event. Please refer to https://docs.microsoft.com/en-us/dotnet/csharp/programming-guide/events/ to learn how to work with events in c#.
