How to add sub element to an equipment prototype through the API
Hi
I am trying to find a way to add sub element to an equipment prototype through the API. I can created the EP and sub elements but now I need to load it with sub elements. Manually this is done in the navigation tree but I dont know how to do it in the API.
4 REPLIES 4
Re: How to add sub element to an equipment prototype through the API
Please have a look into this Discussion.
Best regards
Patrick
Hi
Yes this is to create an EP, I need to add sub nodes to the EP. Or is there a part I am missing
what about this? (haven´t tested)
TxComponent eq = root.CreateEquipment(epData);
eq.AddObject(TxObject);
or
eq.AddObjects(TxObject);
Best regards
Patrick
Hi
Ok I tested this and it does not create an EP prototype with the elements under it. It creates an EP instance with elements under it which seems to not be possible.
