How to check if a component has entities loaded
Siemens Legend Siemens Legend
Siemens Legend
Question:
How to check if a component has entities loaded and if not how to load/unload them?
I've seen the IsOpenForModeling Property but i cannot find a "reload component" method (only "End Modeling" which saves changes) - my intention is to read some data from the entities but only in "read only" mode.
Answer:
If you need only read only access to the entities, you better use the entity level.
Still, for modeling changes we have the following methods on ITxComponent interface – SetModelingScope, IsOpenForModeling and EndModeling.
Load Entity Level can be called from the .NET API using the following code (example):
ITxObject obj = TxApplication.ActiveSelection.GetItems()[0];
ITxStorable storableObj = obj as ITxStorable;
if (storableObj != null)
    TxLibraryStorage libraryStorageObject = storableObj.StorageObject as TxLibraryStorage;
    if ((libraryStorageObject != null) && libraryStorageObject.HasDetailedRepresentation)
        try
            if ((obj as ITxComponent).RepresentationType == TxRepresentationType.United)//if the representation type is Detailed, then it is already in entity level.
                libraryStorageObject.Reload(TxRepresentationLevel.Detailed);
        catch (Exception e)
