How to choose the pick intent as where picked pick using the .net API?
Is there any method in the .net API to programmably change the pick intent as where picked pick?
Jinglin
Re: How to choose the pick intent as where picked pick using the .net API?
Hi Jinglin,
The method to change the pick intent is targeted to be exposed soon.
Adi
If you create a reference in your project to EngineeringInternalExtension.dll, you should be able to get/set both the pick level and the pick intent.  For example:
            TxGraphicViewerEx.PickLevel = TxPickLevelEx.Entity;
            TxGraphicViewerEx.PickIntent = TxPickIntentEx.Snap;
