How to clean OLP commands from a location?
Hello!
I developed an utility to switch location position, where the user selects a pair of locations and their position inside an operation is switched.
I want to add to this utility the capability to also switch OLP commands between locations. For doing that, I need to first clean/clear the OLP commands from one of the locations to only then apply the OLP commands. Creating a new command is not an issue, but I'm not being able to remove existing commands.
Is there any way of cleaning the "Commands" propertie from a robotic location? Is there any other way to implement this API?
Thanks!
Re: How to clean OLP commands from a location?
Siemens Genius Siemens Genius
Siemens Genius
Just use Delete() on the olp object.
Moshe
Hello Moshe!
It doesn't get more simple! I was trying to use Clear in the Commands propertie, forgot to try this option in the object level instead of the collection!
Thank you very much!
