How to create an interference volume
I'm trying to create the interference volume between two swept volumes. Once the IV is created, it looks pretty straightforward to do the calculation, but I can't see how to create an instance.
Since there is no New/constructor for an interference volume, I was hoping to use the same arrangement as with the swept volume, i.e. something like sweptvolumeholdingobject.CreateSweptVolume(SvCreationData),
but for interference volumes there is no analagous CreateInterferenceVolume(IvCreationData).
Any help would be appreciated
Andrew
Re: How to create an interference volume
Currently we don't expose API that creates an Interference Volume. We may consider exposing such in some of our future releases. Currently you can only Calculate an existing Interference Volume, created from the UI. See TxInterferenceVolume class.
