How to define a pose for equipment prototype programatically?
I have created an equipment prototype and created two kinematic links and one joint :
Dim component As TxComponent = TxApplication.ActiveDocument.PhysicalRoot.CreateEquipment(New TxLocalComponentCreationData("equipment"))
Dim link1 As TxKinematicLink = component.CreateLink(New TxKinematicLinkCreationData("link1"))
Dim link2 As TxKinematicLink = component.CreateLink(New TxKinematicLinkCreationData("link2"))
Dim joint As TxJoint = component.CreateJoint(New TxJointCreationData() With {.ParentLink = link1, .ChildLink = link2, .Name = "j1", .JointType = TxJoint.TxJointType.Prismatic})
Than I have open and put in the equipment prototype some previously components with previously created kinematics:
Dim insList As New TxObjectList
Dim libDirectory As New IO.DirectoryInfo("...")
Dim cojts As IO.DirectoryInfo() = libDirectory.GetDirectories("v*.cojt")
Dim pmDocManager As New TxTunePmDocumentManager()
For Each cojt As IO.DirectoryInfo In cojts
    If cojt.Name.Contains(component.Name) Then Continue For
    Dim data As TxTunePmDocumentPrototypeData = pmDocManager.CreatePrototypeData("Fixture")
    IO.File.Delete(IO.Path.Combine(cojt.FullName, "TuneData.xml"))
       pmDocManager.SavePrototypeDataToDocument(cojt.FullName, data)
    Dim inserted As ITxComponent = TxApplication.ActiveDocument.PhysicalRoot.InsertComponent(
         New TxInsertComponentCreationData(IO.Path.GetFileNameWithoutExtension(cojt.FullName),
         cojt.FullName))
    insList.Add(inserted)
Next
component.Paste(insList)
For Each obj As ITxObject In insList
    obj.Delete()
Next
And now I try to create a pose for the equipment prototype:
Dim newDevice As TxDevice = joint.Device
Dim valuesV As New ArrayList
Dim valuesR As New ArrayList
valuesV.Add(CDbl(0))
valuesR.Add(CDbl(1))
Dim modelables As TxObjectList = component.GetAllDescendants(New TxTypeFilter(GetType(ITxKinematicsModellable)))
For Each modelable As ITxKinematicsModellable In modelables
    For Each poseJoint As TxJoint In modelable.Joints
       Dim limits As ITxJointHardLimits = poseJoint.HardLimits
       If TypeOf limits IsNot TxJointConstantHardLimits Then
          valuesR.Add(CDbl(0))
       Else
          Dim hardLimits As TxJointConstantHardLimits = limits
          If hardLimits.UpperLimit = 0R Then
                     valuesR.Add(hardLimits.LowerLimit)
          Else
                     valuesR.Add(hardLimits.UpperLimit)
          End If
      End If
   Next
Next
newDevice.CreatePose(New TxPoseCreationData("V", New TxPoseData() With {.JointValues = valuesV}) With {.CreateAtInstance = False})
newDevice.CreatePose(New TxPoseCreationData("R", New TxPoseData() With {.JointValues = valuesR}) With {.CreateAtInstance = False})
After that I see in the poses editor for the equipment prototype two poses: R and V, but the poses values are set just for the joint j1, and all joints in the sub-components have value 0.
What is the right way to programmatically define poses for equipment prototype?
Re: How to define a pose for equipment prototype programatically?
What you can do is to update joint values directly to the equipment and the subdevices and then to get the CurrentPose of the equipment and use it for the pose data (TxPoseData):
TxPoseCreationData poseCreationData = new TxPoseCreationData("Pose", newDevice.CurrentPose);
Best Regards,
DianaG
Thank you!
Best Regards
ASE
