How to execute command "Load entity level" in API
Siemens Legend Siemens Legend
Siemens Legend
Question:
“How to execute command "Load entity level" in API ? “
I tried to check such function in Help, but I cannot find it.
Pls suggest
Answer:
Load Entity Level can be called from the .NET API using the following code (example):
    ITxObject obj = TxApplication.ActiveSelection.GetItems()[0];
    ITxStorable storableObj = obj as ITxStorable;
    if (storableObj != null)
        TxLibraryStorage libraryStorageObject = storableObj.StorageObject as TxLibraryStorage;
        if ((libraryStorageObject != null) && libraryStorageObject.HasDetailedRepresentation)
            try
                if ((obj as ITxComponent).RepresentationType == TxRepresentationType.United)
                    libraryStorageObject.Reload(TxRepresentationLevel.Detailed);
            catch (Exception e)
