How to find out the fieldNames when using the "GetField" ?
Hi:
Here is what I found in the Forum:
    ITxPlanningObject oRobotProto = pObject.GetField("prototype") as ITxPlanningObject;
    if (oRobotProto == null) return "";
    // get 3D representation
    ITxPlanningObject r3d = oRobotProto.GetField("threeDRep") as ITxPlanningObject;
    if (r3d == null) return "";
    // get 3D file
    ITxPlanningObject pmFile = r3d.GetField("file") as ITxPlanningObject;
     if (pmFile == null) return "";
    string sPrototypeFile = pmFile.GetField("fileName") as string;
    FilePath = sPrototypeFile;
   Where can I find the "prototype" 、"threeDRep"、"file"、"fileName" in the help document? and other fieldnames?
Re: How to find out the fieldNames when using the "GetField" ?
I´m not 100% sure but you can try the following:
Open eM-Planner -> do not load a project -> Tools tab -> Administrator Tools -> Customization.
Here you will see all object from your current customization and all the define classes.
Another way could be. From Navigation Tree select any type you want e.g. ToolPrototype -> File -> Import/Export -> Export Oject -> select *.ppd as file extension.
This file you can open with any editor.
Best regards
Patrick
thanks for your reply
I can find out the fieldnames in ppd.
but i found another problem ,To use the "GetField" method,the model must be loaded first,otherwise the pd will automatically exit.
