How to get PLP's parameters?
Is there a way to the following two paramerers of PLP: Primary Axis and Control Direction?
I will appreciate for any reply.
KX
Re: How to get PLP's parameters?
Hello KX,
Are you familiar with the eMServer API?
If you have a PmPLP object given, then use the server API
HRESULT GetFieldsEx (
[in] EmpContext* Context,
[in] EmpObjectKey* ObjectKey,
[in] SAFEARRAY(BSTR)* FieldNames,
[out, retval] SAFEARRAY(EmpFieldInfo)* FieldsInfo
from the EmpModel Library (EMPMODELLib.dll)
passing the fields
primaryAxis, controlDirectionX, controlDirectionY, controlDirectionZ in the fieldnames array
The values are returned in the FieldsInfo array.
Best Regards,
DianaG
This works great!!!. Thanks a lot.
Best Regards
KX
